Hi all. Long-time reader but rare poster.
I know this has been asked before (I did a search) but I didn't find any new info for my situation.
Got my 21THX the other day. All speakers work fine with it except for my subwoofer. I know the subwoofer itself is fine because it worked fine with my previous Pioneer Elite receiver. Also, I get a thumping sound when I touch the tip of the cable.
My sub is a JBL. Don't have the model number handy right now. I've tried both the LFE and Normal settings on the back of the sub and both the Line and the LFE connections. The Level was set to halfway and the Crossover set to 150 Hz.
On the Pioneer, the cable is plugged into Subwoofer in the Pre-Out section of the rear panel. I've gone into Speaker Settings and set the speakers to Small and made sure SW was set to Yes. I tried Crossover at 80 Hz, 150 and even 200. In the Audio Settings, I made sure LFE was on. When I went into Channel Levels and tried the test tone for the SW channel, I got nothing. Even when I turned it all the way up to the max (+10.0 db I think)
Does it look like the subwoofer connector of the Pioneer Elite is bad? Hopefully, it's operator error, or I've just tried so many things that I missed something. Thanks in advance!
I know this has been asked before (I did a search) but I didn't find any new info for my situation.Got my 21THX the other day. All speakers work fine with it except for my subwoofer. I know the subwoofer itself is fine because it worked fine with my previous Pioneer Elite receiver. Also, I get a thumping sound when I touch the tip of the cable.
