AVS › AVS Forum › Audio › Receivers, Amps, and Processors › *Official* Pioneer Elite VSX-21/23THX Owners Thread
*Official* Pioneer Elite VSX-21/23THX Owners Thread - Page 118
post #3511 of 3519
Originally Posted by Derek Steckler View Post
Hello, hoping someone can help me with an issue I'm having because I'm stumped.
I have a PC outputting video via a DVI to HDMI cable, and audio via digital optical to a VSX-21TXH receiver.
The proper video and audio connections are selected on the Pioneer's home menu.
When I select the proper input and the home menu is on I get audio but when the menu is off and only the PC video signal is displayed there is no audio.
My guess is that when it is displaying the video it is defaulting to embedded audio over HDMI, which is not present.
Is there a way to change the setting for that input so it plays the audio from digital optical instead? (I have the proper optical input selected in the home menu but it is not working.)
I don't want to disable audio over HDMI globally because I have a blu-ray player connected and I would like to use the HDMI audio from it.
Thanks in advance, I'm sure the answer is simple but I sure don't have it!
Hi Derek Steckler, on the remote press "Receiver" and then press "Signal Sel" button a few times to cycle it to "Digital".
post #3512 of 3519
Thanks so much, that did it! I figured it was something simple.
post #3513 of 3519
Well done, I was unaware of this.
post #3514 of 3519
One more question, when I select Auto Surround on a stereo source the sound is tinny with very little bass. This is from both analog and digital sources. PCM Direct or Analog Direct sound much better.
I executed the auto MCACC function which seems to have worked properly but I'm having this one issue. Is there a quick fix for this that does not require hours of manually setting up everything? Thanks for your help.
post #3515 of 3519
I bounced around between Auto/Direct for a long time and finally settled on using the Front Align calibration and Auto for everything.
I have not used this but if you really want to understand what is going on in your room and try to correct it there is a free software called REW available from Home Theater Shack http://www.hometheatershack.com/forums/rew-forum/ and http://www.hometheatershack.com/forums/downloads-area/
There is nothing wrong with liking The way Direct sounds better than the way the calibration sounds.
post #3516 of 3519
Originally Posted by chashint View Post
You will need a phono preamp for the turntable.
Connect the turntable to the amp, connect the amp to the CD input.
Thank you, Chashint (Charlie), for the reply. I've placed an order for a phone preamp and look forward to playing some old albums we came across lately.
Edited by P46G10 - 2/1/14 at 4:08pm
post #3517 of 3519
I abandoned the turntable over 15 years ago, let me know what you think about the experience.
post #3518 of 3519
I hope I’m not resurrecting a dead thread…I have the VSX 21THX receiver, and for years had my setup as a “phantom center” whereas I used the front mains to generate the center channel as well. I’m wanting to experiment with using a physical center speaker, which I hooked up today, and I’m trying to utilize the Center Width & center image features, but I don’t see either option when I scroll through the audio parameters. Is there a certain setting I have to have the receiver in to be able to use these features?
post #3519 of 3519
I have a bit of an issue with DirecTV channels which do not put out a DD signal. Sometimes, when I switch from a channel with DD output to one with without (usually SD vs HD channels) I will get no sound. I can switch to a different source and back and that gets the sound back. I'm connected from the DirecTV box to the receiver via HDMI. Not the end of the world, but an annoyance. Any ideas of what is going on and a fix?
