What happened to this thread in the last week????
Follow up comments in comparison to Noah's experience:
1. I did not have as much trouble with initial setup. Once I had video out set to HDMI and could get to the OSD it seemed to go fairly smoothly.
2. The remote is hard to use with respect to small buttons / labels and orientation of labels to its functional button but is best way to drive the R-972 - buttons on front are not very intuitive - I do not use them at all. I've pretty much switch over to my Harmony at this point
3. The manual is not that great either - I did not use it a great deal and took what my wife would describe as the male (don't ask for directions) approach - just start pushing buttons and see what happens.
4. I did find I could glitch it fairly easily- I repeated the Trinnov setup many times and found some times it would not calibrate (showing 0's for some speakers) - hard rebooting (unplugging it for several minutes)would solve this issue for me - it only happened a couple of times..
5. There is not quick way to do a true A-B comparison with Trinnov on - off due to the delay going into and out of setup / OSD where audio / video is lost. Once you get to Quick audio adjust in the setup and change to Trinnov on or off for comparison it is quicker to come out by just hitting setup again on the remote which takes you straight out rather than arrowing up through all the exits in the hierarchal menu but there is still a significant delay.
6. Trinnov on - off is not earth shaking dramatically different. My wife with her eyes closed can barely notice the difference. I do note the voices are more discretely imaged and the sound stage wider with Trinnov on. Aiming of the microphone with calibration is very sensitive. Slight changes in aiming of the red dot on the front of the Mic in the x-y axis result in significant changes in voice localization. My room is very symmetric - front speakers (Snell CIV) are 12 ft in front of couch and 6.5 ft to each side of listening position. Surrounds are not true surrounds - Boston Acoustic bookshelf Bravos - side surrounds on 10 ft ceiling 7 ft to each side of listing position. Back surrounds on Ceiling 3 ft behind listening position - they rest against a beam that extends down 1 ft. But back wall is open to the kitchen.
7. The Mic cord is short and plug on the back is very inconvenient - I have added a RJ45 plug under the front lip of my cabinet with a Cat 5e cable to the back of the R-972 mic plug and it works well.
8. The button to change the remote to control your CD unit is at the top of the remote. The button to set the R-972 to the CD input is towards the bottom but the labels for the inputs are confusing.
9. Which speakers are on and whether you get all the surround modes is all within the setup for each input source. If say for example for an input source you have Auto surround turned on when you watch that source the R-972 will pick the surround mode and you will not be able to change it manually unless you go back in to setup for the inputs. There are 3 pages of options for each input - you have to be careful what you pick in that menu as it affects what you can and can't do when watching each input.
So I am learning to get around it well. I still have scaling issues. If other folks ever get them I am happy to try and answer questions on set up based on my experience, it is just hard with my schedule to post during the week.
As in asking a question.
