Originally Posted by
Brucemck2
Can someone point me to the proper adapter to connect the R972 Trinnov mic to a microphone stand? The adapter I've got is way too large in diameter.
If I'm reading your post right, you already have a stand, and just want an adapter. Right?
Microphone stands tend to have two sizes of stud diameter: 3/8" and 5/8". So measure your stand, if you have one. The mounting hole on the Trinnov mike is 1/4", which is standard for small cameras.
The stand I use (the one that came with my Anthem MRX 300's ARC kit) has a 3/8" stud, so I bought a simple screw adapter with a 3/8" female end and 1/4" male end. I think it was $8 shipped on eBay from a US-based seller (eBay item # 320847313424).
If your stand has a larger stud, you could use the adapter mjaudio posted above. Maybe there's a 3/8" version of that one, too, if you want the ball joint.
