Let's just say that MNR on the Duo is far from benign. If you have seen MNR on an HQV processor and then seen what ugliness the DVDO can produce in most content you would understand the wisdom of Josh's advice. I leave all the post processing on the Duo off myself. It just is not on the top of the list of things you will find useful on the Duo.. I speak only as somebody who started as an Edge Beta tester in the Edge prerelease days.
Everytime I though maybe it was worth another look it MNR and the other stuff all had problems, and it carries on beyond the current public release. If it worked well, it would be a welcome addition but nobody is going to mistake what is does for a Flea.
Interesting thread...
, otherwise you may be in for the old-school "Bang-Bang" control for passthrough (completely on or completely off - no middleground, no negotiation).
