Originally Posted by
Ronomy
I have a two projector setup so both outputs are active. Popcorn hours remote??
There is a volume control on the popcorn hours remote, which adjusts the volume gain within the PCH, I find this handy when viewing Movies on my TV using the TV's speakers. 'No amp'
Yet unless I have the Second output enabled, then select HDMI 2 ouput, 'even though my TV is connected to HDMI 1' I am unable to use the PCH volume control. Just seem a little backward.
I will try swapping the TV's HDMI lead to HDMI output No2 after and see what brings. Just I find the HDMI 2 output on the Duo to be a better HDMI plug fit, and as my PJ's hdmi cable is of a heavier gauge, it is prone to falling out of the HDMI 1 port.
It really doesn't matter, just one thing I noticed the other night......................... Boy, I'm confused with my own post!
