To be fair, (wife is away tomorrow night.) will pull my Duo back out of it's box, and AutoCal with current manually calibrated settings on my set. Do the reading, then swap back to the XE, and follow through and see it's final outcome. This way, same set, same settings on the set. The only settings that will change, will be inside the Duo and XE. Now, if the Duo wins?
Taking longer than expected and wife came home in not too cheery a mood:
So far - AutoCal Greyscale - toss up - no clear winner, except me. My Manual Calibration is Better than either! Each had pluses and minuses. AutoCal CMS - Duo the Winner. Colour Scale. Pre- 125 Point - Duo the Winner. After 125 Point - not completed. To be finished.
125 Point XE Calibration has messed things up! Going for help!
Edited by p5browne - 12/13/12 at 7:59am
