Originally Posted by
jbdawson
ive got 2 dvds in pal format, how can i convert these to ntsc in the easiest way possible?
can i rip to pc and burn with certain software and set to ntsc? if so what programs can i do this with
They have to be re-authored (therefore re-encoded). There is no other way around it. The two are incompatible formats. There is no ripping and reburning to change from PAL to NTSC.
The simplest way that I have found is to use convertxtodvd to re-author them but you loose the menu (you can create a simple menu if needed using the built-in templates in convertxtodvd). It takes about one hour per dvd.
