I got a new toy to play with! Here's why--I used to have only Rythmik subs in my room, with their built-in LT circuit, which gave me(with room gain) an almost perfect flat response to 10 Hz. Loved it. I moved those subs to the back of my room to fix a problem in my second row. I built a couple sealed subs for up front(LMS and Mael-X). However, I lost that perfect flat response to 10 Hz as the two subs I built started to roll off at 50Hz and 33Hz respectively.
This would be a representative graph
Not bad, but not flat into the nether regions like I had before. So, the Bassis seemed like the simplest way to fix this up.
Here is the LMS close-mic with no EQ, and 4, 8, and 12 db of boost, Fs of 42Hz(box is -3 db at 50 or so, Qtc of .569)
It got even better if I moved the Fs up to 55 Hz and used 12 db of boost, which is where I left it.
It is such an addicting device--you can just keep fiddling with the knobs till you get what you want, although it could be quite dangerous to your drivers
I could go to 60Hz Fs and 16db of boost and get almost flat close mic, but I think that would be a bit much
On to the dual Maelstrom-X box--here is 0, 6, and 12db of boost, with Fs of 30
I settled on 8 db of boost, and Fs of 30. Any other Fs was not helpful at all.
Both of the subs are powered by CE4000's, bridged 220V for the LMS, and stereo 110V for the Maelstrom.
So, I settled on the above settings, and got my connections all hooked up and reran the SVS AS-EQ1. Bosso loves those precise graphs, so I have to show it!
...and then a REW graph at the main listening position
Success!
Graphs are good, and better yet, the sound is phenomenal.
Success!
