AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Onkyo tx nr1007 owners' thread
Onkyo tx nr1007 owners' thread - Page 85
post #2521 of 2618
I recently moved and droped my receiver. It has dent in the bottom corner in back near to the CENTER SPEAKER PIN. I hooked up all the speakers and tested all the speakers.
I am not getting any sound from CENTER and Sourund Right speaker. getting sound from other speakers. Any sollutions? how to test or repair. any ideas, DIY.
Hem
post #2522 of 2618
Hem
Before you send it in for repair, it might be worth opening it up and trying to see what the damage is. It could be something simple like a disconnected wire or it could be something more difficult like a smashed component. If it's the former, you could possibly fix it yourself, or get a local TV repair shop to fix it. If it's a damaged component or circuit, you will probably have to send it back to Onkyo.
post #2523 of 2618
You are right, I opened the back side of the box, had zillions of screws. I couldnt see any physical damage done inside, nor any broken circute. best part, I dont where and what to look for. any suggesions?
post #2524 of 2618
If you can't see any physical damage, then you'll need to send it in for repair I guess. It was worth a look just in case it was something simply. It could be more or less anything that has been damaged when it hit the ground - it will take someone with test tools and instruments to locate and fix it. Sorry.
post #2525 of 2618
Thanks, Is there any fuse or any think specific I can check to see if there is a proble, where is the amp located for center channel?
post #2526 of 2618
I really wouldn't mess with it. It needs proper diagnosis and repair now.
post #2527 of 2618
Guys, I finally fixed it, the center and Surround right channel PCB board was off from the main board. connected back in and now its all working, thanks for inputs guys.
post #2528 of 2618
That's great to hear! Now don't drop it again!
post #2529 of 2618
Good job!! Glad to hear it is working fine. And thanks for confirming that they don't bounce too well
post #2530 of 2618
Thanks guys, I did the setup and now iam keeping max volume but dont see the volume is increasing after +7 to +17. Am I doing anything wrong?
post #2531 of 2618
Thought I'd share my experience with the NR1007. HDMI board finally gave out about a month ago. No network, none of the DSP/speaker icons lit on the left side of the display, etc. Before that the audio would drop out on occasion or while powering on. All the functions, OSD, etc that didn't require sound or the network seemed to work fine.
I E-mailed the Onkyo support people about the problem. Got a response the next day asking for more information: name, address, S/N, bill of sale. My receiver was just over 6 months out of warranty when I sent the mail. They generously gave me a one time extension of the warranty to get the unit repaired. Dropped it off at the service center they told me to use Monday. Got a call today (Thursday) that the HDMI board was bad, a replacement board had been requested Monday, and that the unit was now fixed and ready to be picked up. I was honestly expecting this process to take more than a week, not 3 business days excluding the 3 days spent sending/receiving emails.
After some of the horror stories I've read Onkyo has definitely improved their customer support tremendously. I really can't imagine this repair going any quicker than it did. Not to mention that it was out of warranty and they didn't have to do anything. On the other hand the HDMI board failures almost seem worthy of a product recall. Glad to have this thing back and working. TV speakers on a flat screen just don't quite sound the same!
post #2532 of 2618
Glad to hear it went so fast! Mine took 5 weeks total. I was just glad to get it fixed as well.
post #2533 of 2618
Test.
post #2534 of 2618
I've had my onkyo 1007 paired with an XPA-5 for Over a year and love it. Just recently the XPAg-5 has been turning itself off when the 1007 source changes (like if comercials come on, or if I'm fast forwarding the DVR, or even muting the amp). The power button on the xpa-5 hblinks and the far right led blinks amber (sometimes 2 lights blink amber). I think it's a handshake issue between the twoor something? When my receiver switches modes for a different type of source is when it happens most (although not all the time). And it's never done this until just recently. How can I fix this, it's driving me crazy!!! It seems like the xpa is turning itself off because it doesn't like the signal coming from the 1007 (protecting itself). Any ideas?
post #2535 of 2618
If the xpa5 is an external amp, it sounds like one of your speaker cables is shorting out. Check connections on back of amp and at speakers.
post #2536 of 2618
Hi all,
I added a Panasonic DMP-BDT500 Blu-Ray Player to my Onkyo TX-NR1007.
When I use my analog sound input option (multich sound) does that bypass the Audyssey settings in the Onkyo? Does it bypass the surround sound settings (like THX etc.)?
Is there a way to minimize any video processing done by the Onkyo? I basically just want to pass through the Panasonic signal. If I connect the Panasonic directly to my TV it sounds like a remote control hassle...
Thanks in advance...
post #2537 of 2618
See the Onkyo manual. There is a key press combination that disables the VP on the Onkyo. The downside is that you lose all on screen information from the unit. I did this because the Onkyo's VP by Faroudja had a bug that basically on all implementations. While viewing 1080p24 content it would drop a frame roughly every 41s. That because the VP interpreted 24 frames/s literally. In reality it is slightly less so eventually the processing time was off enough to drop a frame. It's noticeable with fast pans and rolling credits.
post #2538 of 2618
Crap, NR1007 really starting to act up with huge delays in audio on first start of unit. Also problems with HDMI despite it being 'fixed' last Oct... Audio drops 1/2 sec during play back of CDs routinely, sometimes during DirecTv playback, we get minute delays.....
Mark
post #2539 of 2618
I have the tr-nx1007. Is there a way i can make it work with game but listen to another channel. For example, i have a ps3 hooked up to the gaming. but i have an ipod dock set up to the port. both are connected to the receiver. Normally i have to be on gaming so i can see my ps3 and if i switch i wont see it. Is there a way i can be on the gaming but listen to the port
post #2540 of 2618
You could set up second zone.... but, I think second zone would accept only analog sources....
post #2541 of 2618
Just curious. How has your unit be functioning since the HDMI board repair? I just got a call today, after 5 weeks, that my unit was ready for pick up. I will admit that Onkyo stepped up and did a out of warranty HDMI board repair on my unit as well, without me even needing to argue. Im wondering how many have had these boards replaced only to have the problem resurface at a later time? It would suck to get only two more years out of the unit before this board goes bad as well.
post #2542 of 2618
I have a Sony BDP-s790 and can't get audio from the Sony, I have the following:
Epson projector 6010
Oppo 983H
Sony 790
Onkyo 1007
I have the Sony connected to the Epson 6010 using HDMI Video 1, and to the Onkyo HDMI 1 using HDMI Audio 2 in the Sony. I'm using the AV Separation Output Mode in the Sony to send video to the Epson and audio to the Onkyo. I have the Oppo connected to Onkyo HDMI 2. I have the Onkyo connected to the Epson using Epson's HDMI 2.
1) I can get audio from the sony if i disconnect the HDMI cable that goes from the Onkyo to the projector
2) I can also get audio from the sony if I change the settings on the Onkyo to output video from sub and not main output. Once I do this, I can no longer get video from the Oppo.
Any ideas on how I can make it work?
post #2543 of 2618
I am controlling my Onkyo with iRule over IP. Just recently the Onkyo stopped responding to commands. I can ping the Onkyo, but just no command response. I went into Setup and verified that network control was still enabled. Anyone know what the problem could be?
post #2544 of 2618
Pull your power plug out of the back of the avr and let it reset completely. I have to do that with pandora sometimes.
post #2545 of 2618
Ive gotten a new arris pvr from shaw, all is well but i find during shows the listening mode clicks away more than it used to. Is there any way to tell the onkyo to not adjust the listening mode automatically? I think its doing it due to cable signal strength... Should i have shaw cable put a weaker filter in, clickin doesnt bother my wife but it drives me nuts lol
post #2546 of 2618
Just wanted to say thanks for this thread! Mine worked fine for a couple years, then died a couple months ago! I called Onkyo, got a really good guy who offered to cover it out of warranty since this has been a big issue. It's now fixed and back home and working! Without this forum, I'd have probably threw it away and moved on!
Mike
post #2547 of 2618
Pretty sure my HDMI board died over the weekend. No sound from any inputs and no speaker icons, gonna send onkyo an email, I am 6 months out of warranty.
post #2548 of 2618
Looks like my HDMI board died as well,no sound on any inputs,no speaker icons.I called Onkyo,even though my warranty has expired for 25 days they agreed to fix it under warranty!Pheeeew smile.gif
post #2549 of 2618
How good is Onkyo with helping out when out of warranty? My unit purchased in early 2010 has started showing the dreaded no sound at power up problem.
Pretty bummed out, this was my first receiver I've ever purchased. I really was expecting this to last for than two and a half years.
post #2550 of 2618
I'd give it a try. I was quite a bit out of warranty and they helped me out! Can't hurt asking!
Mike
