Figures this would happen at the start of the NFL season!
My Mitsubishi DLP worked fine two nights ago. Yesterday I went to power it on, and nothing. No blinking lights, no red lamp light... nada. I hit the system reset, and there was a click, and the timer light blinked for 90 seconds. I pressed power and still nada.
Unplugged it, pressed power for 60 seconds. Plugged it in, and after 90 sec blinking light, I hit power - nothing.
I tried system reset a few times, without luck. So I sat down to start researching online what could be going on. After about 30 min I heard a *click* sound from the TV. I pushed power on the set and the first time nothing. The second try turned on the TV. Holy crap!
I tried to go to the Input screen to switch from Satellite to Game, and no matter what button on the set was pushed, the main menu (setup) came up - EVEN the volume and channel buttons. Mysteriously after like 15 min they magically worked, and then quickly (MAYBE 5 minutes later) went back to taking me to the Menu.
I tried from the remote, but the TV did not respond to it at all. On the remote each button caused the remote to blink. I swapped batteries on that, but still nothing.
I kept the TV on for about an hour and a half, but had to turn it off. I could not just leave it running all day. Well pressing power did no good (brought up Menu screen), so I had to do System Reset.
After a minute I tried to power it back on, and it will not respond.
I have tried the following:
1) Unplugged for 20 min. Plugged in and pressed System Reset, then Power = no workie.
2) Unplugged for 30 min. Pressed and held Power button for 60 seconds. Plugged in. Hit power = no workie.
3) Carefully removed lamp chasis, and removed the dust from the small airflow screen ( not that much there). Installed again. Plugged in. Hit power = no workie.
4)Unplugged for 5 min. Held in System Reset Button. Plugged in. Hit power= no workie.
5) Unplugged ALL NIGHT. Plugged in. Held Power button for 60 seconds. Hit power again = no workie.
I'm at a loss here. The lamp is fine. No indicator light is on for it, and when it did come on yesterday, the picture was perfect. My set sits on a platform and has very good air circulation all around it.
Anyone have any ideas? I tried calling Mitsubishi, and they said that I tried all that they tell customers to do. They gave me a service company to call, and when I spoke to them, they were going to charge me $100 to just look at it.
I have seen posts of the blinking light of death, and this is not what is going on. The link only blinks when the TV is plugged in, or when I hit System Reset.
What a nightmare! Warranty is out, so I'm stuck with a big 52" brick!
Help?
Thanks in advance!
Help?
Thanks in advance!
