AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Linux-based NMT replacement - please help me choose
post #1 of 11
I've been using a Syabus NMT for a while now, but have gotten fed up with both the user interface and the clunky process for building menus with YAMJ, etc.
A couple of years ago I set up a MythTV box and experimented with that, but ended up going with Windows MCE for TV. Now, I just want to replace my NMT with a Linux-based solution and would like some help.... I've searched/read as much as I can but find as many posts about "issues" with one of these solutions as I find answers.
My only "absolute" requirement is to be able to watch DVDs stored on a network share, with a "nice" interface (cover art, etc.) that is easy to use to select the movie to watch. So, cataloging and displaying the movies is the big question.
The choices I am aware of are:
1) MythTV
2) LinuxMCE
3) XBMC for Linux
One answer is to just go ahead and install of these, but I was hoping that someone who has some experience with them would recommend a "first choice" to save me some time.
Thanks for your help!
post #2 of 11
As long as you don't need live TV viewing / recording, XBMC is far and away the best choice. It has the best UI, best scrapers, and largest development community.
Boxee would be another option, but it is centered primarily around web video. Its network media library features are somewhat limited compared to XBMC.
post #3 of 11
I wanted to build a HTPC but with things like WDTV and Bite view only costing $100, it's hard to justify building an entirely new pc *just* for xbmc.
post #4 of 11
If you can live with 720p, you can install XBMC on an AppleTV, which you can get refurbished for $150.
Also, the OP is specifically asking about HTPC frontends under Linux.
post #5 of 11
Probably best to browse the HTPC forum and then ask questions there. In this forum, you are more likely to get people trying to talk you out of a HTPC.
post #6 of 11
Thanks! I thought that XBMC looked nice, but wasn't sure if the Linux port was ready for prime time yet. I think I'll give it a try first.
post #7 of 11
I am putting together an Atom-based HDMI (Nvidia) PC for less than $200, so the step up from 720p isn't all that much more......
post #8 of 11
I am pretty sure that XBMC is developed in Linux and then ported, so the Linux version be the most advanced.
post #9 of 11
The Linux and Mac branches are pretty much in sync. Installing Linux on the ATV is possible, but it's more trouble than it's worth. You're better off sticking with the stripped-down version of Tiger that it ships with.
Some good news if you're considering an ATV: 1080p h.264 is coming soon.
post #10 of 11
Thank you for the link. That would be incredible. I am astonished.
philip
post #11 of 11
I set up XBMC over the weekend, and it is exactly what I was looking for. Getting it set up with all the right drivers working (graphics, audio, IR) took a bit of time for me (linux challenged), but there is a lot of information out there to work through the issues.
Thanks again for the pointer.
Zyll
