Originally Posted by Charles Hansen
For many years, the Theta Casablanca has been accepted as the best sounding processor. I largely attribute that to its volume control (and, I believe, discrete circuitry). 99% of all SSP's use nothing but op-amps in the analog signal chain and IC-based volume controls that simply don't sound very good.
Charles, very interesting thread that I just stumbled upon. You probably have an opinion on the issue I am facing. I own a casablanca III and a six shooter and (hopefully within the next few months) will have to make a decision about which way to go for multi channel, once Theta delivers their HDMI upgrade. If I get a top of the line source component (e.g. your Ayre), do you think the HDMI route will sound better than analog through the six shooter? The six shooter does not have the limitations of using analog bypass in a SSP.
Alterntively, if I had to decide between spending 10K on the source component (e.g. Ayre) and running it through the six shooter OR upgrading the Theta to HDMI (in which case I would not be able to afford the top of the line source and had to use a HDMI from the standard Oppo), which investment would give me the best sound you think. Just curious about your opinion. Note that the entire trade off is based on multi channel - for 2 channel I will use a server for convenience.
Read an article the other day describing how labour intensive converting old 2d movies into 3d is ; the media will be thin on the ground..
A few have caved in;
