Originally Posted by
GGA
The outgoing audio signal does not contain any video. It is output as balanced MMHR (Multichannel Meridian High Resolution, RJ45 connector/CAT5) or single ended as Smartlink (S/PDIF or when encrypted it is called MHR, RCA connector).
OK, I corrected the original post. Sorry for the error. I think I need to eat lunch or something...
GGA
One may choose to output video over HDMI or just the audio. Perhaps you mean the incoming signal is polluted and stays polluted because they don't separate the ground?
No, I was confused. It is relatively easy to isolate the grounds of an S/PDIF signal using pulse transformers. Many companies do this, although some use a transformer but then ground the input anyway, which defeats one of the main advantages of using a transformer! I would assume that the Meridians have transformers on the inputs of the SSP's as this is a fairly common practice. I have no idea if they use them on the HD621 or on the MHR Link.
With isolation, this device could be very helpful. Without isolation, it is just a way to add HDMI to an SSP that doesn't have it built-in.
GGA
The HD621 does accept 100-250V. Does that automatically mean it is a switching power supply?
Yes. Always.
I didn't need to look at the photo to answer that, but if you look at the photo the thing in the black cage is the switching power supply.
GGA
No one else can really use it because of the encryption and there are no other SSPs I know of with 6-channel digital inputs.
I didn't realize that the S/PDIF's were also encrypted. That's the trouble when you are part of the DVD Forum -- you have to play by the rules....
GGA
Meridian retail price is $3000. The Theta upgrade price or release date has not been announced but the speculation is that it will be more and may require replacement of the DAC cards. A new Meridian 861 version 6 will set you back some $26,000 or more. Meridian processors nowadays seem to be designed to be used with their digital speakers. Their top DSP8000 speakers are $65,000 a pair, up from $40,000. They use zeroes differently than most of us.
Yes, I think Meridian has deliberately designed a system that really only works with other Meridian equipment. You either sign up for the whole kit-and-caboodle or you don't. Some people bought their G series CD players as stand-alone devices, but once you get into their SSP's I think you pretty much need an all-Meridian system...
