Originally Posted by
IngoT
First, I don't want to switch on the TV set or the beamer when listening to music only.
Yes, it is somewhat annoying to have to do so. With the C-5xeMP, one can navigate most any disc without the need for a display. But since the DX-5 will usually be connected to a display, there are some discs that require the display for proper navigation. However, once you have found the proper starting point, you should be able to turn the display off while listening to the rest of the disc.
IngoT
Second, normally I listen to two channel music by the DX-5's XLR output feeding a Mark Levinson No. 326S and a pair of No. 436. In case of SACD two channel, I prefer DSD. Only for multichannel purposes (SACDs and BluRays/DVDs) the separate AV preamp (Marantz AV7005) comes into the game. It is also connected to the ML326S to reproduce the main channels in the multichannel layout. Center and surround signals are amplified by a separate Marantz MM7055 5 channel power amp. The AV 7005 does not accept DSD signals, thus PCM conversion is required for multichannel SACD listening.
That is the best way to connect it for multi-channel music.
The one thing that will tend to degrade the sound of your system is the fact that the Marantz is connected to your display. If you are not using the display while listening to music, you can improve the sound of the system by plugging the display into a switched outlet strip. Normally the display has a switching power supply that is running even when the display is in "Standby" mode. By turning the switched outlet strip off, the switching power supply will also turn off. However, you will need to turn it on manually.
Also, if you have a connection to a cable system, I would recommend using an isolation transformer such as the Jensen Model VRD-1FF:
http://www.jensen-transformers.com/iso_vid.htmlQuote:
IngoT
I use overall 5 video sources, including the DX-5. They are all HDMI-connected to the AV7005, which serves as a switch, a scaler, and a multichannel decoder and in addition distributes the signal either to my beamer or to my TV set. Connecting the DX-5's HDMI Audio output to the AV7005 and its HDMI A/V output to the beamer directly would result in best audio and video quality but skip the option to watch video signals from the DX-5 on the TV, unless I install an additional HDMI switch, which I would like to avoid. Maybe I use the composite video output of the DX-5 for connection to the AV7005, just for purposes of usage of the on-screen menus of the DX-5. I will think on it...
I don't know what the other 4 sources are, but I am confident that the DX-5 will provide the best picture quality. However, the Marantz has the Anchor Bay ABT-2015 scaling chip. This is essentially the same chip as is used in the DX-5 but is on a newer (90 nm?) process that requires no heatsink or cooling fan. So it will do a good job with many sources. Inside the DX-5 it has the advantage of having the frame cues transmitted to it directly rather than having to try and interpolate to figure out which frames are which.
But as soon as you connect another video source to both the display and the audio system, then the audio isolation is shorted out. It's not ideal, but you will still be better off using the DX-5. Both the video quality and audio quality will be better than your other sources. I would definitely not recommend relegating the video output of the DX-5 to a composite monitor!
Most displays have multiple HDMI inputs these days. That would solve one problem. I don't know if you would gain anything by using an external HDMI switch over the one that is built into the Marantz. They are inexpensive enough that it might be worth a try just to see if it looks or sounds any better.
Please keep us all posted as to the results of your experiments!
