AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Insignia NS-BRDVD3 - Netflix & BD-Live - Want Your Opinions
Insignia NS-BRDVD3 - Netflix & BD-Live - Want Your Opinions - Page 14
post #391 of 1008
Originally Posted by mdavej View Post
I believe MTS files are AVCHD, so renaming won't do it (I think). I just use the software that came with my camera to burn those to a DVD in AVCHD format. The resulting disk plays fine. Otherwise you'll have to re-encode to some other format (and probably lose quality in the process).
Did you read my post? I renamed the AVCHD MTS files from my camcorder, and they did play from a thumb drive.
post #392 of 1008
Originally Posted by Dannychico View Post
Go to Windows Explorer (windows key + E). go to the tools menu up top. go to folder options. click the view tab. scroll down about halfway and uncheck "hide extensions for known file types." now all those 00001 files should be 00001.mts
Awesome, thank you.
post #393 of 1008
Sweet. I missed that. Post corrected.
post #394 of 1008
Originally Posted by Lane F. View Post
A new firmware was released today for the wireless model. Does anyone know what it add/fixes? I'd hate to update it only to wish I kept the version I have...
The only thing I can say about it is that we watched UP tonight and it skipped a few minutes at one point (we went back and it did the same thing at the same point), then we updated the firmware and it played fine. Don't know what else it fixed though.
post #395 of 1008
I found answer, no thanks to Gizmodvd. A simple "it was covered earlier" would have been sufficient.
post #396 of 1008
picked this up last night...at my BB store it rang up at $150...but its on sale for $99
post #397 of 1008
i just picked up the wsbrdvd from bb yesterday so far im quite impressed, the netflix feature is better than it was on my samsung bs1600
post #398 of 1008
Hooked up the wireless version, took awhile to get my wep wireless going, forgot a digit....Doh!, well it was a open box return and the only one left, the box said $149...no wonder nobody touched it, my wife called me and she said it was a open box and had to tell them it's onsale for $129, well, i said if it's a open box should get some more off, got another 10%
Before i updated i could not get Xvid to play on disc or usb, it had the previous firmware, like the BRDVD3 that firmware disabled .Avi playback, well after update they both work well, very pleased with .mkv playback also
This player does everthing i wanted it to do and netflix streaming is very good.
If it only could recognize my network files it would be the ultimate!!
Only peeve is the rear usb, i'll have to get a extension.
post #399 of 1008
I updated last night. Will see if it fixes the .avi problem soon.
post #400 of 1008
Good. Glad to see you actually decided to read the thread for a few minutes. When I walk in Best Buy I don't go "where is abc movie?" I actually attempt to find it...myself.
post #401 of 1008
Wired or WiFi version?
post #402 of 1008
Bud-man, glad to see that you're well enough to play with your new toy, sounds like a good deal. Now don't over do it with the turkey.
post #403 of 1008
WiFi Player Update
- Now play's .Avi's!
post #404 of 1008
Originally Posted by alleng View Post
I just bought the wbrdvd model. This is the one with Wifi. $129 at BB. It connected with my G network with no problem. Downloaded the firmware update. It works with Netflix. HD is almost like HD OTA TV. I can't believe how easy it set up. And for only $129. I have ATT DSL. It still works pretty good. My router is 2 rooms away from the player.
What is your ISP speed?
Just curious to see if it's less than 3mb or greater since you are playing Netflix HD.
post #405 of 1008
gizmodvd-I guess you're just rude. 400+ posts is more than a few minutes.
post #406 of 1008
See the Search link at the top of the page?
You can add any of these fine things to it:
avi, mkv, divx
and get your answer.
post #407 of 1008
Man, I got to give props to GizmoDvD.
It was he who saved and made available the previous firmware that I am using right now.
I don't think he was rude, as just being Captian Obvious to you, erick.
Anyway,Gizmo, thanks for being on this forum and helping people.
Lyndon
post #408 of 1008
No problem, I'm not a computer guy. Just asked for a little help-that's all. No worries. Happy Thanksgiving to our American cousins!
post #409 of 1008
This player now seems to be $199 at BB. What gives? Raise the price >50% for Black Friday? That's a new one.
post #410 of 1008
The wireless version went back up to $199(regular price).
The non-wireless is $99 starting tomorrow.
post #411 of 1008
wired version
post #412 of 1008
When I have checked the speed, it has come in at about 2.5 mps. Nothing special.
post #413 of 1008
Wireless version is still $129 and Non-wireless is $99.
They had plenty in stock at my location(Southcenter/Tukwila, WA)
post #414 of 1008
Ill need to rebuy 2 Wired ones today for the free BDs and return them with my old receipt.
post #415 of 1008
Best Buy is now charging $199 for the wireless version. This player isn't worth that much. Better to go with the LG 390 for a bit more. Apparently the $129 sale was this past Wednesday only.
post #416 of 1008
I thought I'd share some more information in the ongoing question of "What is this a clone of"
I checked out my friend's new Momitsu 799, and the menu and display graphics are all identical (save for the different company logos in the background). The setup menu looked and read the same, with the same wording on display options like "16x9 pillar box." The play/pause menu was identical as well.
Now, the 799 is considerably smaller than the Momitsu, so I wonder how it might compare to the 899. However, neither model's region remote codes worked for me, and the Momitsu remote looks nothing like the Insignia/Samsung. (It doesn't do Netflix either.)
Anyone make anything of this? Do a lot of companies share graphical elements in their firmware?
post #417 of 1008
I guess YMMV on the $129 price. Mine had a stack with about 20 of these next to the HDTV's on the wall with the $129 price. The $99 players were on the other end of the isle adjacent to the $129 players.
They had about a pallet of the $99 players at 12pm when I went there(BBY) for the 2nd time. Everyone seems to be eatting up the name brand blu-ray players.
post #418 of 1008
Is the only difference between the wired (BRDVD3) and the wireless (WBRDVD) the wifi capabilities (or lack thereof)? Do they have the same .avi/.mpg/.wmv reading abilities?
post #419 of 1008
Only difference is the wireless ability, however you may need to use the firmware posted by GizmoDVD for .avi playback on the non-wireless model.
post #420 of 1008
wait what...free bd's? is that a black friday deal only...i wonder if i can bring my receipt in and get free bd's as well?
edit: i see this is friday and saturday only, so i'll go today and see if i can get the beetlejuice bd for free
