Originally Posted by Bud-man
...so i removed the 2 screws and removed the top drive cover to expost the laser, well i used alcohol, Q-Tip and cleaned the rubber circle the motor uses to spin the disc......It Worked!!
Appears dust and crap get's built up on the cushion/rubber ring and the disc does not spin fast enough on initial start.
Kudos, Bud-man.
I did what you described and, at least for now, my NS-BRDVD3 seems to be fully functional again. I have, however, relegated it to "back-up equipment" status. Thanks for the tip.
(Yeah, if you read through this thread the problem was found to be the "smoked"/tinted plastic covering the sensor on the front of the player. Someone posted pics of a DIY project to either scrape the crap off that section of the plastic or even just drill a hole in the plastic to uncover the sensor -- both of which fixed the problem.)
