AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › cleaning a panny 3000 filter
post #1 of 4
Before you yell at me I DID SEARCH!
I was reading about the 3000(which I own) and I see that people are cleaning the filter every 100 hours. Is this necessary and if so how do you do it. Thanks for any help.
post #2 of 4
bump
post #3 of 4
The why and how are detailed on page 46 of the owners manual. If, for some odd reason, you don't have the manual, you can d/l here...
http://www.projectorcentral.com/pdf/...anual_4506.pdf
And it is better that you refer to the manual rather than us try to explain. The illustrations make it a lot easier.
post #4 of 4
Just one precaution:
Remember that the dust will be in the external side of the filter, so, if You are gonna vacuum the filter, do it always from the outside of it and use the vacuum cleaner at low power. If You are gonna blow it with compressed air, do it from the inside.
