I've been trying to decide between a Denon 2310 and a Pioneer Elite 23THX. I went to the Magnolia section at my local Best Buy to check them out. During the demonstration, the Pioneer sounded stronger in the mid-range and little thin in the bass (the tests were done without subwoofers) while the Denon seemed to have a little more bass throughout. Both sounded good, but I ended up feeling that the Denon had a warmer sound that I preferred.
I left the store wondering if what I heard was actually true of both receivers or whether I was just listening to the default settings without any kind of EQ applied. Short of setting up the receiver in your home using your speakers, can you really tell much about a receiver in a store situation like Magnolia?
