Hello
I know the Sony projectors have good points and bad points. If we leave that behind in this discussion and debates if Sony can tweak the cr performance.
Over the years Sony has slowly improved sxrd performance. The first introduced 4k panel was speced at 4000:1.
Now with pressure coming from JVC Sony has what it seems taken quite big steps with their latest home cinema units. The vpl-vw85 is expected to have between 20k-30k:1 at the projector level depending on the setup.
I know the home units are low in brightness but I am asking what a high brightness around the corner 4k sxrd projector could do with improved panel technology.
Uniformity is often brought up and that is why I can not understand why Sony is not already using a cooler light source. With less heat too dissipate off the panel uniformly I expect uniformity is easier to achieve.
