Originally Posted by
JonStatt
I just tried this on a 950. I am not sure quite what I am looking for. There are some funny glitches (distortions/ slight shimmer) as the boxes slide back and forth. But I do not see anything turn pink at all.
Thanks for the feedback Jon and for checking this! Basically the best way to describe it is this - on the RS20 (and presumably all other models prior to the RS15/25/35), as the boxes slide horizontally the thin white lines that run through the boxes turn light red.
In other words, if you look at the boxes closely (OTTOMH) you will see they are made up of intermittent lines/pixels, which forms a white or gray lines within the boxes. As the slide those intermittent lines turn from gray/white to a redish/pink. As soon as the boxes stop sliding, it turns back to its normal color.
If you do not see any red fringing in the box while it is sliding, so that its color is the same as when it stops at the edges, then we have good reason to believe it is resolved.
Also please try watching CNN HD or another HD channel in 1080i and watch the scrolling new ticker at the bottom. Does it look nice and white? If the issue is resolved then you should not notice ANY color change in the ticker when you pause your DVR. For instance on the RS20 it looks fairly white, but then when you pause the DVR to freeze the ticker from moving, you can see it instantly turn a more solid white.
Oh and another thing to check if possible - do you have a PS3, or any other way to display 720p? If so, please have it display 720p and then switch to a 1080i signal. Try switching back and forth a few times. Do you get a random splash of color on the screen for a split second (somewhere between 25-100% of the screen turns a certain color for a split sec)? This is something else that would be nice if they have resolved it.
