Hey all.
My 1st question is, should a riser be put or built all the way up against back and side walls??
2nd, is there a need to put plywood underneath ur riser to say...close it up (if that makes sense)?
3rd, is 13" too high a riser for a 2nd row of seating with a step @ 7.5? Just want to make sure the 2nd row of peoples views are not blocked by any heads...etc.
Going to be using 2x12s, 2x8s, and 3/4" sub floor plywood. Going to glue dwn plywood with liquid nails after filling with insulation. Is it better to use nails or screws for riser? Also, is there any advantage or disadvantage in using u boats so that ur riser is suspended and is there anything wrong with no using u boats and just having the base/frame of ur riser just laying on top of the felt? Sorry, really confused-lol- Any tips or suggestions are fully welcome =)
