Originally Posted by Anthony A.
okay understood. im gonna fiddle around with the phantom keypad trick. so just to confirm then, if i plug in these strings into the HAI controller:
\\x0D\\x0AKBP, [01:06:10], 1\\x0D\\x0A
\\x0D\\x0AKBP, [01:06:10], 2\\x0D\\x0A
then when the alarm sounds, it will toggle these on? and when i want to turn them off, simply go to that specific keypad and the led should be illuminated and i can then toggle it off?
and what if the "INTERIOR" button is already engaged when the alarm sounds, does the lutron processor know its current state and the HAI will keep them on and not turn them off? (kind of like a discrete ir command)
Try this.
In Illumination
Go to Programming
click Security
You now have a bunch of options on what you would like security mode to do. Lights to be toggled, keypads to be disabled, ect. You will also see a checkbox for "restore all lights to previous levels". Check that.
Now create a phantom keypad with just two buttons enabled.
Select the first button and name it "Security Mode On". Click the globals tab and select security mode from the list, make sure "begin" is selected and add it to the button.
Select the second button and name it "Security Mode Off". Click the globals tab and select security mode from the list, make sure "terminate" is selected and add it to the button.
Now you can program your security mode in Illumination and only have to worry about pressing one of two buttons to toggle security mode off and on.
This has an added benefit. When you terminate security mode it will restore all lights/cco's/ ect to the level they were at before security mode was activated.
