Hello, i want to connect a powered subwoofer to the 876, but the 876 has one pre-sub out and my sub has a L and R audio input plug.
So one wire from the Onkyo and no matter what plug i use, no sound !
The sub only "hums" a bit and it has a dB gauge but no reaction.
I looked inside the air vent port and see the amplifier, and from the L plug comes a white wire and from the R plug a red wire.
Those wires go the the amp.
So how do i connect the (mono) wire from the Onkyo to the 2 input plug sub ?
Thanks for any help..........
. I had LFE setting with my 886 set incorrectly at 80Hz, it is recommended to be at 120Hz. After changing the setting and rerunning Audyssey I found bass response to be much better. I have found that with a setting or two set incorrectly it can really throw off the SQ of your system
