I have a DirecTv box in room A and a hdtv with mutlti-channel receiver in room B. I also have a cat 5 cable running from room A to room B for the function of IR control to change channels on the DirecTv. I purchased an IR receiver and cut the plug off and exposed 4 wires. (red, white, yellow and black). I assumed 2 were for powering the IR receiver and 2 were for the IR flasher, but when I hooked them up I received no power on the receiver unit, and the function of the unit did not work either. Am I mistaken on how a IR receiver works? Using a multi-meter tester I was able to separate the colors of the wires to there relative position on the phono plug (tip, ring, sleeve etc.) but that doesn't answer what wire provides what function.
Ryan
Ryan
