AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Software › Blu ray HD audio question - DRC with Phantom Center?
post #1 of 6
My reading suggests older dolby digital formats engage DRC with a Phantom center - Is this the case with newer HD codecs?
post #2 of 6
Does anyone know this?
Mod Edit: Please do not bump your threads....if someone wants or knows the answer..they will post it.
post #3 of 6
What's DRC. I run my setup with a phantom center...because of my wife.
post #4 of 6
Dynamic Range Compression... Ruins the peaks in your audio by limiting dynamic range to "protect" the speakers.
post #5 of 6
This is a good question. I would like to know the answer. Make no mistake though, HD audio codecs can be light years better than Dolby Digital...keyword "can".
post #6 of 6
As a reference for others...yes, it did for me on Total Recall 2012: a disk from Netflix, DOlby TrueHD.
  Back to Forum: Blu-ray Software
