I am looking at a used SIM2 Domino 30H. The seller says the machine will tell you how many hours the bulb has left but not how many the machine has. That doesn't sound right to me. Is that correct. I can't imaging there isn't a menu option that would tell total hours.
I am also curious if the DLP bulbs get significantly less bright over time like LCD bulbs do? This person says there are 3000 hours left on the bulb. The bulbs are good for 6000 hours but I don't know if they take high output into those numbers or not.
Anyone with experience with the SIM2 bulbs, the rate at which they fail, how fast they loose lumens and at what percent do they loose them would be helpful.
Thanks in advance.
Lance
Thanks in advance.
Lance
