Hi there,
I have been using my PT-AE4000 for about a month now (about 70 hours on the counter). Everything was great, except that a couple of days ago, I noticed a circular spot about 2 inches of diameter on my 92 inches screen. It is visible only when the screen is black (during PS3 game loading for example). The spot is just slightly less black than the background, and the spot is almost perfectly circular on about 75% of the circumference. I have cleaned my lense, but that did not make any difference. Furthermore, the spot is always there on any mode.
Does anybody have an idea what could be the problem? I guess I will have to send the unit back. Unfortunately, I am in Canada and bought the unit online in the US. I will have to send it back to the US, since Panasonic Canada does not cover US unit.
Thanks for any advice!
Moral of the story- you can damage you unit when trying to remove dust blobs. I personally refuse to ever do it again.
I am glad I saved it, I knew it would come in handy one day.
