Originally Posted by lawsab
I have an AE4000. My throw is about 10ft. I am currently projecting onto my dark brown wall and am deciding on what type of screen to buy. I have samples from Elite and Carada. I run the lamp in eco mode. I use the Color 1 setting, no additional tweaks.
I put up all the samples, and watched the intro to star wars. I noticed that the image of space on my wall was "black." However, when I looked at the screen samples (CCW, brilliant white, cinewhite, cinegray, HC gray) the "black" space image was lighter and more of a "blue" space image.
How can I get the screen samples more "black" and less "blue?" I fiddled with contrast, brightness, gamma, etc. and NOTHING changed the "blueness" of the screen samples. Does this mean I have to get a black screen? Tweaking wise, is there anything else I can try to make the blue more black? Hell, Id even prefer "darker gray" than blue.
The gray screens did produce somewhat of a darker blue, but I cant figure out why the screen samples are blue looking.
Those samples shouldn't be blue, especially not in Color1 mode. I think what may be happening is it just looks blue because it's surrounded by a brown wall.
Your color perception is completely relative to surroundings. That's why colors look normal when you're in a fluorescent-lit office, but when you take a photo, everything looks green. The light actually is greenish compared to incandescent light or sunlight, but your brain compensates. In your case it thinks the light is brownish, and that small sample is therefore perceived to be blue. Do you have a bedsheet or something else large and white you can surround the sample with?
If you have a 10' throw, then you'll need a fairly small screen. So you could get away with a gray screen if black level is very important to you.
