Originally Posted by RDoherty
The other units are labeled CEC compatible, although the only effect I see is when I shut off the projector the other units turn off also. Which is kinda neat. But the other units don't turn themselves on when the projector is turned on, and the projector doesn't turn off when something else turns off, so it really doesn't help with the remote control problem. There doesn't appear to be any serious menu control other than enable/disable.
Some where in the menu of your BD player, receiver or the A4000 you have the option of having them just turn on, or on/off or other remote commands, depending. There are a lot of variables here, but the more CEC devices in the chain the more they can conflict with on/off of each other.
