Hi, denada:
The vertical shift is 100%, which means you can position the projector 1 full screen height from the screen center along the vertical center line. So if your screen height is 60", your projector can be 30" above or below the screen.
The 40% is for the horizontal shift. I'm less sure about it, but it should mean you can position the projector 40% of screen width from screen center along the horizontal line. So basically, if your screen is 10' wide, your projector can at 4' off screen center either to the left or right.
Don't know if there is a web site for this or not.
Hope this helps.
Hope this helps.
the exception would be rooms that have recently undergone construction. Let such rooms sit for a week and wait for the dust to settle, prior to firing up any open light path optics projector.
