Originally Posted by switchg3ar
I am really considering this projector; I have a few questions for you guys. I have been looking around the forums and I can't seem to find a clear answer.
This is my setup; I have 16:9 motorized screen. When I watch a movie in 2:35.1 I understand I will get the letter box on the top and bottom. Can the lens memory be programmed so that when the projector sees 2:35.1 content it will shift the lens position down so that the image is touching the black bottom border? If so is this done automatically when it sees the content? I understand the zoom and focus can be stored but can vertical shift be stored? I've looked in the manual, I am not finding a clear answer. The closest I found was you can do electronic image shift but not a lens shift. If someone could clarify this for me I would appreciate it.
Can the projector recognize the content and performs all of this or would I just have to hit one button?
I am going to put a vertical masking system on the top if I can just shift the 2:35.1 image down on the 16:9 screen I am set. I am going to have a motorized black blind drop an inch in front of the screen to cover the top part.
I'm thinking this will likely work, but the key is probably in the vertical height of the projector lens in relation to the screen? Where is it positioned?
) advice, which is why I described my setup as one data point. His amazing theater has much darker wall treatments than mine (wife had input in my case
). Another key factor is that my screen has only 1.1 gain, you can of course get much higher than that.
