Originally Posted by TVAddikt
Thanks for the info. I am in the process of making my new HT work. Have you ever setup a wall wart like I described in order to act as a 12 volt trigger? The two questions I had in that setup are:
1. Yes it is a 12 v wall wart but it puts out 1.2 A. Is 1.2a to much?
2. Do I need to add anything else in between the wall wart and the projector?
My HT has quite a few components that need to be activated in order for a move to happen. So I am trying to keep my options open.
Sorry never had a wall wart.
I use the harmony to do everything in the theater. One push of the power button does everything.
1) turns on Reciever
2) Turns on Zone 2 which triggers the amps
3) turns on the projector
4) opens masking on the screen
Off does the same in reverse, guess I see no reason to trigger the projector. Actually that could be a bad thing as some times we just turn on the reciever for music and don't want the projector on.
