Are you sure that's not an automatic message? I know on my ViewSonic, it started advising lamp replacement at about 40% of the expected life. I ignored and it's still going strong 1,000 hours later. Unless you are noticing degradation, I'd ignore. Just my dos centavos.
I would not sit around worrying about it, the Panasonic's in general have had excellent reliability (their build quality and QC is better than many other brands).
They are different companies though, no? Pureland and Pureglare. One based in PA and the other in CA
I personally will never buy from anywhere but B&H or Provantage when it comes to bulbs and only genuine PANASONIC bulbs. There are so many horror stories that saving a few bucks isn't worth the potential nightmare and poor performance.
I would not be afraid of the Pureland lamps. Pureglare seems like a nightmare company. I have purchased two from Pureland with no problems. Have one in my Epson 8500UB with about 1100 hours on it now.
Where can you find these projectors for $800?
I just bought a second home with a dedicated theater room. After making it my own,(black walls and ceiling with grey crown molding), I put my flagship projector there.
My problem is I miss it in my old home. I put up my old AX200 but now I really see the difference. I'm toying with the idea of buying another AE 4000 because I can't afford a AE 7000 or 8000.
I logged on to this thread to check the reliability of this PJ and found that you love your projector after 4 years as much as I do.
I bought from Pureland just recently and their replacement bulb seems to work just fine so far. They are also located only about a 2 hour drive from me, so I can show up at their door if needed.
It did not, though my current air filter is quite clean. I clean it out monthly, just in case, and it is never very bad. It is washable - just make sure you let it fully dry before putting it back in. I vacuum mine out again after washing it, just to be sure.
