CALIBRATION USING YCPR 4:2:2 AS A COLORSPACE SOURCE (BLUYRAY OR PS3...) AT YOUR DISPLAY OR VIDEO SETTING:
1st you need to update your pj if not 2.51 you can check up by pressing manu botton then to the left arrow at the down youll see a number 2.1 or ... this is your pj version if its not 2.51 then you sould download the fimware file 2.51 then load it through update program under utilities section its so easy to do just follow the pdf instructions that comes with update program zip file.
http://www.viewsonic.com/products/pr...rs/pro8100.htm
for calib:
wen you press the manu botton at your pj remote you have picture , config , hqv , memory, pcs settings.
with your remote you have botton says "picture mode" click at it till you have "cinema".
then you have anothert botton says color temp click at it till you have "user"
then press manu botton and choose the following:
select picture manu:
enter the following;
Contrast=39
Brightness=64
Saturation=54
Hue=50
sharpness=26
then
select config manu:
enter the following:
Black Level=low with iris 3 or set black level to normal for more detail but less black
Color Space=Auto
Lamp Mode=Normal or eco as prefered for new lamp or high gain screen
Auto Iris=on
Daylight Sensor=Off
then
select HQV manu:
Detail Enhance=5( wen there is A HIGH noise decrease till noise BECOME LOW)
Film Mode=Auto
LTI=auto
CTI=auto
select memory manu:
User 1 Setup for best color mode:
Gain R = 521, G = 342, B = 360
Offset R = 506, G = 512, B = 516 .save to user1
select user 2 and enter the following:
User 2 Setup for bright mode
Gain R = 512, G = 466, B = 470
Offset R = 512, G = 512, B = 512 save to user 2
the best mode is cinema with user 1
the brightest mode is cinema with user 2
then for setting ur iris to 3: at the remot arrows do the following:
up,down,left,right,down,up,down.up, manu botton
some advices for using ur pj:
every 6 hours of running this pj rest for 25 min( cycle 2 hour rest 20 min) , clean existing filter every 50-100 houre to ensure dust protection , unplug your pj before going to bed to eliminate any vertical noise issues could happen because this pj is abit sensitive to video signal during standby mode, operation should be between 60-95f temp, wen you want to operate : 1st turn on the pj then after the lamp reaches full power turn on other playing sources, do not shack or vibrate the pj while its turn on, never ever unplug wen its on because it needed 3 min internal fan cooling after turn off thats it
