AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Samsung B860 Series
Samsung B860 Series
post #1 of 3
Any word on whether or not the B860 will come out in a 63" was considering the 65v10 Panasonic when my friend said check out the Samsungs and I was blown away by the picture. But only in a 58" size, sitting 16' away from the set I was hoping for the couple extra inches.
post #2 of 3
There will be no 860 in 63".
The best 63" Samsung makes this year is the 590. It is thicker at 2.9” than the 860 but not more than the 65v10 (and far lighter than the v10). And the picture is pretty close to the 860. Thickness aside, it retains the look of the 860 (which is universal among the Samsung line) with the glass bezel. The swivel stand is glass instead of metal like on the 860. Feature-wise, it loses the Internet features of the 860, but it has more inputs and better internal speakers.
post #3 of 3
bluewaves, the Samsung 63B590 is an awesome set. I had a chance to watch and play with it the other day at BestBuy. Unless you just really want an ultra thin plasma, there is no reason not to consider that TV.
