Right, so no building progess.....we need a "need money? lets start a business thread" this forum is motivating enough
So a bit of down time, back to some planning work. Just so you all know, I'll be using the AVS/Erskine layout service, but I haven't put pen to paper on my ideas yet so I'll be slowing updating here, time permitting. Of course Dennis/his people might give it the thumbs down, but these are just my thoughts for the moment.
Proposed Soffit:
So there are two here, ones got the rear speaker placement and the other will run along the rest of the room. The speakers I have are designed so that they can be placed flush at 45 degrees aimed at the listener, or just hung on a wall as normal. Made by Vaf Research, its called Soundwall.
I am told Soundwall has the following off axis response:
- Around +/-3db out to over 13,000hz as wide as +/-45 degrees
- Actually its supposed to be a little better than that
With Speaker
Without Speaker
So these will run along the room to the front, where I'll have a larger box as a soffit leading into a bar diffuser.
Question - is the 140x140 triangle large enough to move air in/out of the room?
This is the proposed dead vent that I'll have under the house, adjacent to the room in void space - it'll be hung on isolated hangers. I'll build an MDF duct from the dead vent to the soffit, again hung on isolated hangers and attached only to the new ceiling, not the existing house/framework. Oh ignore the different sizes, I couldn't be bothered changing it on sketchup, they'll be the same in/out/duct size
