Originally Posted by nube
Your initial reaction was:
And now, after EQ'ing just a little bit...
Are you as impressed as you thought you'd be? Do they outgun your Empires by alot? Give us some details, man!
I'm glad it's worked out for you.
JTR makes solid, solid products. They ain't cheap, but nothing good is.
A couple other things to note. That Live Free or Die Hard scene is definitely well known as a demo. The whole movie is! As Archaea says, adding subs makes it the main event!
Also, I wouldn't bother with an Audyssey XT32 receiver down the line, if you're still considering one. I'm not convinced at all that the results are worth the huge price tag. I think you'd be much better off with amp + the simple external EQ of, say, a miniDSP. But, that would probably require you to get REW capabilities. Not that going there is a bad thing, by any means; it's prolly the best overall choice to make in the long run.
JTR makes solid, solid products. They ain't cheap, but nothing good is.A couple other things to note. That Live Free or Die Hard scene is definitely well known as a demo. The whole movie is! As Archaea says, adding subs makes it the main event!
Short answer: yes, they definitely outgun the Empires. By a wide margin.
After the placement shifts and EQ, I can definitely feel the low end more and especially that last 1/3 octave in the 15hz tune. I do still want an XT32-equipped AVR as I'm interested in (and surely in need of) correction of the entire bandwidth.
Additionally, I'm not sure how the miniDSP works....if I recall, it is not an automated process at all. If that's true, are there algorithms included to take multi-position sweeps and create a wider sweet spot, a la Audyssey. I'm not interested in a ruler flat FR if it's only available in one seat, to the significant detriment of all others.
Next thing I need to work on is finding a quiet fan. If the scene goes from heavy bass action to quiet quickly, you'd think a Harrier was setting down in my theater room
(at least I assume that is what I'm hearing and liking right now).
