Originally Posted by
mastermaybe
I already have one, thanks. And thanks for the CV option, but I'd prolly pass on it over a Crown unless I were to find out a little bit more about who's building them, how.
All a bit moot anyway as Jeff does NOT offer a passive S1 or S2.
James
Correct. I asked him about this back when the sealed designs were in the planning stages and he mentioned that it's a cabinet construction limitation. As I understood it at the time, the back opening for the amps cannot be easily sealed in a passive version, and asking the cabinet maker to do a custom design is a lot of extra work.
jdlynch
I'm curently debating the Cap S2 to the Seaton Submersive HP. If I go with either I will only be able to afford a single as opposed to duals of a lesser sub like the HSU ULS-15.
I've got a call into Jeff with some questions, but, there is one I forgot to ask him:
Is the DSP Jeff uses with the S2 pre-set to match the amp to the drivers/enclosure by Jeff , or, is it something I can perform manual EQ with to suit my room?
Apologies to the Submersive HP, but if you can afford it, the Captivator S2 will likely offer a significant boost in output compared to the SubM HP. Dual 18" vs. Dual 15", and the dual 18" have greater xmax, so much greater displacement. Plus, they have more power going to them to get that extra output. A single Captivator S is roughly the equal of the SubM HP in blind testing, so the S2 should have all the same +6dB.
As to the DSP, it's not defeatable on either the SubM or the S2, though the SubM does have two program settings, 19hz (program 1) and 15hz (program 2). This shouldn't worry you at all. You can still apply EQ after the fact, and this is actually a good thing (contrary to what CHT says).
errivera
There are no external controls (other than 'level' pot)... the DSP is set at the factory and not user adjustable.
On the S2, this is correct, but that's not a bad thing. The factory-set DSP is a great feature, and doesn't impede using your own EQ in any way. I'm sure you know this firsthand, being an S2 owner, but I thought I'd clarify for others.
jdlynch
Thanks for the response. Can anyone comment on the quality of the finish? From the looks of the photograph on the JTR forum it is pretty basic and far from attractive. Are their premium finishes available for the S2?
I'd say it's much like a Duratex finish. It's lightly textured black and extremely durable - the finish is several coats and is very thick. My only minor gripes with it are that after a year, I can see some seams showing through it
and it does scrape off onto my tile floor if the sub is moved at all.
