Originally Posted by
ratm
Holy Crap. Wow, where to begin. Ummm.
I'll start with a simple one. I am getting a CRAPLOAD of hum, that I never got with my Empire. Any ideas?
ratm
hogues
I had that and my cable was not properly grounded.
what was your solution?
ratm
i just used a cheater plug, which i know is not optimal, but it eliminated the hum. Now on to calibration
I need to pull this out as a sticky/resource on my forum, but I posted some solutions I've found with grounding
originally on my own forum, and
later posted it here on AVS.
In short, try grounding the receiver/preamp and then can use the grounding as intended. The issue is always one of floating and different grounds, so no single item causes the problem, only specific combinations. Of course none of these problems become audible until you connect a speaker, so we as speaker manufacturers are the ones who get to do the troubleshooting...
