Originally Posted by Jedirun
I run my S2 on a dedicated 20 amp circuit. Many people run these on non-dedicated circuits without issues.
I am not sure what the cost was because I did it in conjunction with other required electrical work. If this helps give you an idea, it cost $1700 for 3 dedicated 20 Amp circuits run to the theater and the replacement of several circuit breakers in the breaker box that had failed or were failing.
Does it matter if I rarely, if ever, will push this cap/amp to its limits?
