Just renovated a large room (attached), mounted a large plasma, and am now looking for a home theater system. However, I'm no expert in home theater.
So I found the Denon - 375W 5.1-Ch. Home Theater System at a local Best Buy (http://www.bestbuy.com/site/olspage....=1218088196263). Although I'm no expert on systems, the price is right ($599) for my budget. But there are two problems.
The first being it's on backorder from the manufacturer and I've never had luck when trying to purchase anything back-ordered.
The second is I can't seem to find anyone at Best Buy who can answer, what I think, is a basic question. Will this systerm work for the following?
- My room is pre-wired for 6 speakers. Plans are to use the front 4 speakers for the home theater and the 2 far rear speakers (in conjunction with the front 4) only when playing music from a connected IPOD. Can this system be wired for this?
Does anyone know if this system will work as described or if there is a closely priced solution with similar quality (and I'm hoping this Denon is of decent quality)?
Thanks in advance.
Thanks in advance.
