Hey Guys,
I'm new to projectors, but in doing my research it seems that the PT-AE4000 will work perfect for my setup and budget.
I'm planning on a 100" screen and it looks like my max distance away from the screen is about 10' to 10' 5" depending on how the mounting goes.
Would the PT-AE4000 be able to handle this ok? I've been using this calculator:
Projector Central
and it looks like it will work, but just barely, so I wanted to ask you guys to make sure.
Also, I may end up having all 3 front speakers behind the screen so I'll have to go with an AT screen. Since those screens don't have much gain, will it help me that the projector is so close and help make up for the downfalls of an AT screen?
TIA, this forum has been amazing for me to start learning about PJ's.
Projector Central
)... Fortunately it could be turned off easily enough. And (2) default color settings cause a lot of purple lips and slightly off reds at times... But side-by-side comparison of image should make it easy to fix that when I am not busy watching stuff on it!
