I am looking to build a new home and have been looking through a lot of floor plans for those having a family room conducive to putting in a "theater." In spite of this, I have found a plan that I really love, but I have reservations regarding the a/v layout in the family room.
EDIT: The plan in this message (while I'm leaving it here) fell through
. I will post the newest plan below.
Here is the floor-plan in question:
There will likely be some modifications, as follows:
1) Wall off "dining room" entirely and add French doors; increase size to 16x13 to accomodate pool table.
2) With the size change, I will be adding 5' to the rest of that side of the house, and I'll probably split it to give 3' to the kitchen and an additional 2' to the great room. This will bring the great room size to 20'x21'8"
Here is a picture of the proposed room from above:
:drool: I'm in love, this design firm put together an awesome plan, IMO.
With the additional of 2' in the great room, I figure I could pull the couch back a few feet, which will give me the ability to put floor standing speakers further out into the room, which I suppose is generally a good idea. I would also probably put the rear speakers on stands or in the rear wall, I'm leaning toward the latter.
My reservations are the following:
1) Mounting the plasma above the fireplace. It seems I should have enough room to pull the couch back far enough that you won't have to strain your neck looking up at it. But, in general, it seems this is "frowned upon." Thoughts?
2) Where the heck do I put a center channel? Wherever it goes, it will not align with the floorstanders if I pull them out into the room. I could probably have them dig out beind the mantle so the center will fit on top of it. But, it'll be substantially behind and above the floor standers. Problem?
3) I doubt I will be able to find in-wall solutions with a prayer of filling that room. That being said, I go back to 2. I suppose in-wall front speakers would be able to line up better, but I have a feeling I'll sacrifice a lot taking that route.
4) The space is huge, and with that high ceiling, I'm worried that it'll become an echo box with little hope to control the sound. Ideas?
5) Filling the space. If I go floorstanders, I can look into something efficient like the Klipsch Palladium (which would also look gorgeous in there) but...then I'm back to 2. Maybe just go phantom center? I keep coming back to that issue.
6) What the heck am I going to do for a subwoofer? That area is massive. I suppose I can try to have them push some nooks to both sides of the fireplace so I can put a pair of subwoofers in them to be flush with the front of the fireplace and "out of sight". IB would be sweet if I have a basement...since it's being built I could maybe stick the vent(s) on the sides of the fireplace. Thoughts?
I also have a feeling that I underestimating just how big that room really is. And making it even bigger so I can "pull out the floorstanders" and have room for the couch may be a misconception. I mean, it'd have to be a darn big couch to suck up all that width.... I suppose keeping the room smaller makes it easier to fill, but...argh, ideas?
Any ideas? Or...go look for another floor-plan, lol. Maybe I'll get "lucky" and this one will be so far out of my budget I won't have to think about it any longer, lol. This room seems, daunting.
Lacking ideas, can anyone recommend a knowledgable theater consulting company in the South Jersey area?
Sorry for the long post. This is my first home and I want to do it right. But, I am a bit scatterbrained and paranoid about it. It is as if I have this overwhelming fear it will come out bad if I don't plan it to perfection. So...any help you can lend, or ideas, would at least calm me down.
THANKS Y'ALL!
. I will post the newest plan below.Here is the floor-plan in question:
.Here is a picture of the proposed room from above:
THANKS Y'ALL!
