Hello! First of all I have a HTPC that works fine, using Zoomplayer with several different codecs in order to try and get the best video and audio I can get - but I mainly use ffdshow and CoreAVC, Reclock (my plasma doesn't support 24fps) and Zoomplayer as frontend (except for DVDs, I have to use Cyberlink DVD player, can't get Zoomplayer to work properly).
My HTPC is connected through optical to a Denon AVR 2106 with Monitor Audio silver and bronze speakers (5.1) and a Panasonic TH-42PY70 plasma. My HTPC has a 8800GT video card, no sound card, quad core processor and 4GB memory (I use it for occasional gaming too).
I guess many of you have similar setups and I'm quite happy about it but what's your experience between different music and video codecs to get the best quality possible (bit for bit image and sound)? Or should I let the amplifier to the job, even if it means losing some frames with 24fps sources?
Let me give you an example for which I don't have an answer - would it be better to configure AC3/DTS passthrough using SPDIF or ffdshow audio (or another codec) does a better job than using the amplifier to decode the sound?
Finally, what are the best codecs for HD sound? My amplifier doesn't support the newest sound codecs...
Thank you for your answers! This is the very best forum to read and learn.
Bruno
Bruno
