AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › onkyo pr-sc885 with oppo bdp-83
post #1 of 4
I am looking for a blue ray player. I plan to get the onkyo pr-sc885 or 886 pre/pro. So the pre/pro should do all the audio decoding. Is it worth getting the oppo over the ps3 slim? I don't plan on using SACD's.
post #2 of 4
You might want to ask your question here.
Oppo vs. other Blu-ray player thread.
http://www.avsforum.com/avs-vb/showthread.php?t=1136139
post #3 of 4
Since the 885/886 has very good video processing, you may want to consider a less expensive BD player that supports source-direct video output... this allows the signal to be passed with minimal video processing by the player and allows the AVR to do the bulk of the processing.
post #4 of 4
Use post in either the sticky thread "help me chose a BR player" or the thread linked by petmic for comparisons to the OPPO or the OPPO tech. master thread.
This thread is locked
