AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › Access HD boxes @ Rite-aid $40 (or free)
post #1 of 7
Rite-aid is selling the Access HD boxes for $40 this week if you still have a coupon left (mine was due to expire next week).
I picked up a Model DTA1030D
Now to read\ est if this box is any good.
post #2 of 7
I would avoid it but for free, what do you lose? This is what I found out about it:
Now the bad news. I can only describe the picture and sound quality of the DTA1030D I purchased as POOR when used with it's internal RF modulator. the picture had moire patterns (internal interference), poor gamma/chroma relationship (unnatural colors in dark objects) and obvious buzzing in the audio when tested on three different TV sets. An external RF modulator ($13 at Family Dollar) solves the problem, providing fine picture and sound, but it makes more sense to buy a CECB with an acceptable internal RF moduator anyway. I cannot recommend the DTA1030D to someone who intends to use it with an older TV that lacks video/audio inputs (e.g. the 5" battery-powered B&W I had intended to use it with).
http://www.wtfda.info/showthread.php?t=2622
post #3 of 7
Ah, a drug store CECB (i.e. Craig, etc.).
post #4 of 7
The Craig is a much better CECB over the Access 1030 or 1080.
post #5 of 7
Well my coupon was due to expire next week, so I figured even a low level box was better than an expired coupon.
post #6 of 7
At Rite-Aids here, the Access STB's are kept behind the counter for some reason, so if you don't see them ask the sales droid.
post #7 of 7
To put them further away from the front counter?
