Originally Posted by _Outlaw_
Lindsey in response to your post from the other thread: The circles that I saw (and I say "saw" because they are gone now) Were about 4 inches round and went from left to right across the middle of the screen. It only happened when I enabled Smart LED to ON. As soon as I put it back to off they went away. Almost looked like rain on a camera lens effect.
Any suggestions??
Any suggestions??
AFAIK "SmartLED" is what Samsung calls it's local dimming implementation.
If you have to switch it off to get the picture look "normal" you actually switch off the sets most exciting feature. Without it you cannot reach the black level and contrast this expensive set is capable of.
In other words: You lose the very reason you bought this set and not a cheaper one.
You may be content with what you see because you don't have comparisons at hand or you are still too excited about this set but if you have to disable local dimming because it doesn't work correctly you have a serious problem.
=> Get it either repaired or replaced.
bye
Benny
lol
