this is a quote from another thread in another site but the main point is this receiver shuts off immediately after turning it on several times then will remain on for the duration and here is a recommendation. Any other recommendations would be great.
Thanks for the advice, do you know this for fact? I just tried what you recommended and it shuts down right away now. Everything is unplugged turn it on and immediately turns off.
If this is the case its this any easy fix I can do myself? And is it pricey?
