Originally Posted by
Goba
I opened this thread for people discuss Network issues in WDTV Live!
I think is better to compile all the info in one dedicated thread!
posted in the other thread but since you're trying to pull network problems together...
Can't see any shared folders on my XP computer.
Am I'm just missing how to select? I'm looking for movies installed in a shared folder on my desktop so on the WDTV I select VIDEO, press enter, NETWORK SHARE then enter again on the remote, but nothing, no prompt for user or password, no files. Same if looking for a shared music file, nothing.
From a desktop computer can move files off and on the WDTVLive, play them on the PC etc. I've followed instructions for sharing, turned off the Windows Firewall, turned on the user guest account, run the Network Setup Wizard, but no luck.
I have since connected a laptop to the router and with it, can see the shared files on the desktop (and also the WDTVlive) so appears no problem with the shares on the DT or firewall on the router.
I'm XP (SP3), wired connection with a Trendnet router (TEW-432BRP) that shows on the supported list.
